- Engine Liquid-cooled, four-stroke single, DOHC, four valves per cylinder
Displacement 449cc
Bore x stroke 96 x 62.1mm
Fuel Injection 32-bit digital, with 42mm Keihin throttle body
Starting Electric
Transmission Five-speed with reverse
Final drive Two-wheel drive, chain
Frame type Aluminum double cradle, racing type
Front suspension / wheel travel Dual A-arms, coil-over shocks / TBA
Rear suspension / wheel travel Swingarm with piggy-back reservoir shock, dual-rate spring / TBA
Front tires AT21x7-10
Rear tires AT20x10-9
Front brakes Dual 163mm discs with two-piston calipers
Rear brake 200mm petal-type rotor with single-piston caliper
Overall length TBA
Overall width TBA
Overall height TBA
Seat height TBA
Wheelbase TBA
Ground clearance TBA
Lighting Dual removable headlights
Dry weight TBA
Fuel capacity TBA
Footpegs Sport-style serrated
Color choices Lime Green / Super Black, Bright White / Super Black, Super Black
Kawasaki KFX 450 R Nowy ścigant z zielonej stajni
- Krzysztof Wronowski
Garść danych technicznych nowego modelu:
- Załączniki
- kfx450r_3_d.jpg (39.96 KiB) Przejrzano 3200 razy
- kfx450r_2_d.jpg (38.67 KiB) Przejrzano 3199 razy
- kfx450r_1_d.jpg (44.81 KiB) Przejrzano 3207 razy
Ostatnio zmieniony pt 15 gru, 2006 przez Krzysztof Wronowski, łącznie zmieniany 1 raz.
- prezziguzzi
- prezziguzzi
