Kody błędów cf moto 800
Cf Moto 800, błędy na wyświetlaczu 0131,0174 ktoś coś?? Przy dużym.obciazeniu potrafi przerwac...
- tede74
- Administrator
- Quad:: Scrambler XP 1000 S
Re: Kody błędów cf moto 800
Tu masz kody błędów:
FAULT CODE TABLE:
P0107 MAP Circuit Low Voltage or Open MAP-Manifold Absolute Pressure
P0108 MAP Circuit High Voltage
P0112 IAT Circuit Low Voltage IAT-Inlet Air Temperature
P0113 IAT Circuit High Voltage or Open
P0117 Coolant/Oil Temperature Sensor
Circuit Low Voltage
P0118 Coolant/Oil Temperature Sensor
P0122 TPS Circuit Low Voltage or Open TPS-Throttle Body Position
P0123 TPS Circuit High Voltage
P0131 O2S 1 Circuit Low Voltage O2S-Oxygen Sensor
P0132 O2S 1 Circuit High Voltage
P0032 O2S 1 Heater Circuit High Voltage
P0031 O2S 1 Heater Circuit Low Voltage
P0201 Injector 1 Circuit Malfunction
P0202 Injector 2 Circuit Malfunction
P0230 FPR Coil Circuit Low Voltage or Open FPR-Fuel Pump Relay
P0231 FPR Coil Circuit Low Voltage or Open
P0232 FPR Coil Circuit High Voltage
P0336 CKP Sensor Noisy Signal CKP-Crankshaft Position
P0337 CKP Sensor No Signal
P0351 Cylinder 1 Ignition Coil Malfunction
P0352 Cylinder 2 Ignition Coil Malfunction
P0505 Idle Speed Control Error
P0562 System Voltage Low
P0563 System Voltage High
P0650 MIL Circuit Malfunction MIL-Malfunction Indicator Light
P1693 Tachometer Circuit Low Voltage
P1694 Tachometer Circuit High Voltage
P0137 O2S 2 Circuit Low Voltage
P0138 O2S 2 Circuit High Voltage
P0038 O2S Heater 2 Circuit High Voltage
P0037 O2S Heater 2 Circuit Low Voltage
P0500 VSS No Signal VSS-Vehicle Speed Sensor
P0850 Park Neutral Switch Error
P0445 CCP short to high
P0444 CCP short to low/open
FAULT CODE TABLE:
Circuit Low Voltage
To ja też mam...ale błąd 0174 t.nie występuje.
